Home :: Powered Slider Trike Basic Rear End Kit (Without engine and transmission components)
ABSOLUTELY BRAND NEW basic complete slider rear end kit! Bolt-on and GO!
CPR Axle parts are known throughout Australia as being the best quality anodised components available at low prices. We buy in bulk and offer a great range of vivid anodised colours including Blue, Black, Red, Gold and Silver. Scroll down and click the PRODUCT REVIEWS banner below to learn how others have rated our products. You won't be disappointed with this kit!
All nuts and bolts are included to connect up the rear end.
Includes:
1x Complete 40mm project axle kit (Your choice of colour - Black, Blue, Gold, Silver or Red)
1x 40mm Axle Shaft ($120)
1x Drilled Brake Disc ($120)
2x CPR Pillow Blocks ($49.80)
ALSO INCLUDES the following nuts, bolts, and fixations:
Axle Length: 1050mm
Keyway locations:  from end to end:
@ 10mm->75mm
@ 120mm -> 185mm
@ 350mm->400mm
@ 740mm->790mm
@ 975mm -> 1040mm
Standard Pillow Blocks
1x CPR Recreational Hydraulic Brake System
1x Pair of Rear Wheels and Tyres
210mm mag-style magnesium rear rims with rear tyres 11x7.10-5
Comes with everything you need to connect it up and use.
Just add Engine & Transmission, Frame, Seat, Front wheel and hand controls and you're in sliding!
DriftTrikeGuideGuide
SKU KSLDR2
Base product price: $879.00
