Home :: Plastics & Numbers :: Plastic Plastics Side Pods set PAIR Left and Right (New Style)
*New Model Side Pods set.  Can be used for both 2 stroke and 4 stroke kart applications.
Suits newer model karts with straight (90degree perpendicular) sidepod bars.  Can be easily modified to suit older karts.
Kit comes with both sidepods.
Dimensions:
Sidepods - Length = 600mm, Width(at centre) = 180mm, Height = 200mm,  Front cowling adds 95mm width to sidepod just behind front wheel.
Dimensions of sidepod picture:
SA - distance from divet to edge of front of sidepod = 70mm
SB - distance from divet to front bolt hole centre = 35mm
SC - bolt hole centre to bolt hole centre = 457mm
SD - rear bolt hole centre to rear of pod = 55mm
SE - Total length of sidepod = 617mm
SF - distance from rear bolt hole centre to centre of divet (cutout for bar) = 75mm
Brand New.  *New Model SidePods set - Suits 2 stroke and 4 stroke karts.
47%
SKU PSPC1
