Home :: Tools, Starters & Chargers :: Tools :: Piston Stop Crank Lock Clutch Removal Tool Billet
Billet aluminium.
SAFE CRANKSHAFT LOCKING TOOL
Our alloy crank lock tool won't damage your piston or crankshaft.  The tool will completely stop the crankshaft rotation and makes the process of removing the clutch locking bolt simple and easy.
WON'T DAMAGE YOUR PISTON FACE!
COMPATIBLE WITH KART ENGINES
CPR crank/piston locking tools work on all engines using standard 14mm x 1.25mm pitch threads as used on almost all karting engines including Honda, Briggs, Rotax, Yamaha and loads of others.
SO EASY TO USE
CPR crank/piston locking tools simply wind into the spark plug hole - just remove your spark plug, wind the crank lock tool all the way in and rotate your crankshaft until it stops.
 It’s really that easy!
CPR PERFORMANCE
CPR products are considered among the most reliable karting components available in the karting industry.  You can rely on our range of tools to help you drive faster.
Crank locking tool (Piston Stop) to enable the fitment and removal of clutches and sprockets to and from Honda, Yamaha and Rotax engines.
Easily remove your clutch and re-install with this simple lightweight and durable tool.  Soft enough not to damage piston surfaces, hard enough to remain reliable.
Use fingers to tighten or 19mm socket.
NEW.
ClutchChangingGuide
TCCGuide
SKU PSTC01
