Home :: Engines, Carbs & Parts :: Pistons & Conrods :: Piston Ring Set THICK TYPE suit Standard 70mm Piston and EPSKA2 Predator (old style with pressed silver valve cover) 70mm Flat Top Piston
Piston ring set to suit Predator 212cc Non-Hemi Head style - type with silver pressed valve cover DOES NOT SUIT TORINI CLUBMAXX
THICK STYLE RINGS
SUITS EPSKA2
Top Ring .057", 2nd .057, Oil .094
(1.5mm Compression Rings)
SKU EPRSPNB
