Home :: Engines, Carbs & Parts :: Pistons & Conrods :: Piston Ring Set suit 88mm Standard GX390 and Clone
OEM CPR stock size piston ring set 88mm bore. Approx 1.95mm thickness compression rings.
SKU EPRSC3
