Home :: Brakes & Parts :: Hydraulic :: PACK Hydraulic Brake Kit including Master & Calliper PLUS Brake Disc & Hub suit 40mm Shaft
BRAND NEW Hydraulic Brake Calliper and Master PACK includes Master, Calliper, Lines, Brake Hub & Disc to suit
Approx 70cm long line.
Suit up to 6mm disc.
Replacement pads available from us for $19set.
A= 63mm, B=Up To 6mm, C=36mm
Suitable for most brands of recreational go karts.
 Disc Dimensions:
Brake Disc Thickness @ 3.5mm
Need a brake disc to suit?
30mm Axles:
40mm Axles:
SKU BPKC40R
Regular price: $180.82
Price with FREE DELIVERY: $169.90
$79.00
$34.95
Brake Pads Linings (suits BKHC02)
Brake Pads Linings (suits BKHC02) Brake Line Hydraulic 6mmOD 4mmID per Metre
$19.95
$7.95
$9.95
