Home :: Brakes & Parts :: Accessories & Parts :: Olive (Inner) for Brake Line
Brand new olive to suit Brake Line (Hydraulic) with 4mm inner diameter.
You'll need both the outer and inner to complete the flange. This is designed to create a flange to fit into any flanged standard connector (such as T split connector, L connectors on callipers, or I connector on master cylinder.
If you buy our T, L, and I connectors you will not require an inner olive. Those connectors are complete with all olives required.
SKU BLOIH1
