Home :: Racing Simulator Parts & Retro Computing :: BOBOVR F2 Active Air Circulation Facial Interface for Oculus Quest 2
Want this fast? We'll always ship the same day before our cut-off by courier. If you're in a hurry to recieve your item, that's ok - you'll get it the fastest when you choose our express shipping options - areas within the Aus Post express shipping network will receive the parcel the next day! Awesome right! That's why we're known in the karting industry for Australia's fastest dispatch!
Adapted to Oculus Quest 2, Includes a replacement of the Official Facial Interface and a rechargeable micro silent ventilation host, Replace face cover and face pad
Active ventilation system: equipped with a micro turbofan, which can quickly exhaust the air in the mask, prevent the lens from fogging, and relieve heat accumulation
Support Type-c interface charging (same as the official charging interface of quest2), the micro turbofan can work continuously for 3-5 hours when fully charged
The host weight is only 30g, 2 levels of air volume are adjustable. In the high mode, The air in the Facial interface can circulate more than 30 times in 1 minute
Use softer PU leather and foam padding, which is easy to clean and keep dry. And use nose pads to prevent light leakage during use. The whole design is to increase your comfort and extend the use time.
All for a better VR experience
The R&D engineers of the BOBOVR team found in the test that the original Face pad is easy to absorb sweat and produce peculiar smell during long-term use of Quest2, which causes the face to become hot and foggy. To this end, the BOBOVR team spent 6 months for 3 iterations of the version. Re-optimize the problems reported by everyone, including possible loosening of the buckle and the upgrade of facial fillers,The official version of F2 uses a soft sweat-proof leather design, and the leather surface can be cleaned by simply wiping with a damp cloth. And with the miniature active air circulation fan, it greatly relieves the accumulation of damp heat and mist on the face.The micro-host integrated battery and control system weighs only 30 grams,Reduce overall weight.
BOBOVR F2 is a complete Face interface package, it contains the following parts
Mini active fan
Rechargeable design, can work continuously for 3-5 hours when fully charged, Quiet, the soft wind does not irritate the eyes
Face interface
ABS+PC material, can replace the official face interface, with vent design, directly fixed with F2 host
Face pad
Using flexible sponge and skin-friendly PU leather, sweat-proof, can be wiped clean quickly,and is fixed to the face interface by Velcro
Emergency charging cable
When the battery of the host is exhausted, it can be directly connected to the quest2 charging port for power supply
Light-blocking silicone pad
Adopts a flexible bending design, which can block most of the light entering through the bridge of the nose
Lens cloth
Using flexible and slender suede technology, it can easily wipe the dust and perspiration on the lens
SKU BOBOVRF2
