Home :: Engines, Carbs & Parts :: Pistons & Conrods :: OEM CPR Piston Ring Set suit 68mm Standard GX200/160 and Clone
OEM CPR stock size piston ring set 68mm bore - same as the ones used in our high quality CPR Lifan engines.  Approx 1.25mm thickness compression rings.
SKU EPRSC1
