Home :: Engines, Carbs & Parts :: Pistons & Conrods :: OEM CPR Piston Ring Set suit 90mm THIN 1.2mm suits CPR 90mm Flat Top Piston Predator 420 Hemi Style Engines
Predator 420 (Hemi style) engines 1.2mm thickness compression rings.
Top Ring 1.2mm, 2nd Ring 1.2mm, Oil Ring 2.4mm
FITS:  90mm Predator Hemi-Style Flat Top Pistons using thin rings (1.2mm) - same as the type used in Predator 420 (Hemi style) engines
SKU EPRSCT5
