Home :: Engines, Carbs & Parts :: Pistons & Conrods :: OEM CPR Piston Ring Set suit 90mm THICK 2mm suits CPR 90mm Flat Top Piston GX390 and Clone
OEM CPR thick-style flat top piston ring set 90mm bore - same as the ones used in our high quality OEM CPR 90mm flat top piston kits.  2mm thickness compression rings.
Top Ring 2mm, 2nd Ring 2mm, Oil Ring 2.7mm
FITS:  90mm CPR Flat Top Pistons using thick rings (2mm) - same as the type used in our EPSKA42 Flat Top 90mm Piston Kit
SKU EPRSCT4
