Home :: Engines, Carbs & Parts :: Pistons & Conrods :: OEM CPR Piston Ring Set suit 88mm THIN 1.2mm suits CPR Flat Top Piston GX390 and Clone
OEM CPR thin-style flat top piston ring set 88mm bore - same as the ones used in our high quality OEM CPR flat top piston kits.  1.2mm thickness compression rings.
Top Ring 1.2mm, 2nd Ring 1.4mm, Oil Ring 2.6mm
FITS:  88mm CPR Flat Top Pistons using thin rings (1.2mm)
SKU EPRSCT3
