Home :: Engines, Carbs & Parts :: Pistons & Conrods :: OEM CPR Piston Ring Set suit 68mm THIN 1.0mm suits Honda and CPR Flat Top Piston GX200/160 and Clone
OEM CPR thin-style flat top piston ring set 68mm bore - same as the ones used in our high quality OEM CPR flat top piston kits (also fits genuine honda flat top piston).  1mm thickness compression rings.
Top Ring 1mm, 2nd Ring 1mm, Oil Ring 1.4mm
FITS:  68mm Honda and CPR Flat Top Pistons using thin rings (1.0mm)
SKU EPRSCT
