Home :: Engines, Carbs & Parts :: Pistons & Conrods :: OEM CPR Flat Top Piston & Ring & Gudgeon Pin & Clips & Billet Conrod Kit for Race Spec GX200/160 and Clone
1x OEM CPR Flat Top Piston & Ring Set complete.  OEM Piston from our reputable Lifan premium quality engines.
1x Gudgeon Pin
1x Pair of Gudgeon Pin / Piston Clips
1x Billet Rod ARC Pro Series Billet Alloy Connection Rod featuring the industries only forced oil dipper for superior oiling to the crank pin. CNC machined from 7075 T-651 aluminum and are designed to withstand the rigors of today's high horsepower kart engines. These rods boast advanced oiling design and high strength ARP rod bolts. These are simply the best rods money can buy. Rod includes bearing and bolts.
Oil gap clearance < 0.004" and greater than 0.002"
Cap bolt torques ~ 150in/lbs (moly lube on threads) or ~170in/lbs (oil on threads)
PLEASE NOTE: These are US designed and have imperial bolt heads.
Suits Honda GX200 & GX160 & Clone Engines.
Replacement bearing available: ECBBM1
SKU EKMMCR
Regular price: $249.82
Price with FREE DELIVERY: $249.00
