Home :: Plastics & Numbers :: Number Plates & Numbers :: Number Pack 3 Digit - 6x Rear & 6x Side Black or Red AND Decal pack with Rear Bumper Decal White or Yellow
**PLEASE NOTE: NOT ALL COMBINATIONS OF NUMBERS WILL FIT ON THE PLATE/BACKGROUND IN THIS SET AND/OR WITH STANDARD SPACING BETWEEN THE NUMBERS - 3-DIGIT NUMBERS WITH 1 AS ONE OF THE DIGIT WILL GENERALLY FIT, BUT OTHER COMBINATIONS MAY NOT**
We do not guarantee that all 3 digits will fit on the standard backgrounds without modification.
If you would like us to check a combination for you, feel free to message/email us prior to purchase.
Full set of 12x AKA compliant digits.
A full 3 Digit set. 12pcs total.
BRAND NEW AKA Legal quality Numbers Easy to read, modern italic typeset.
These are a much better looking number than most other karts and at an extremely low price.
They are proper precision cut vinyl - NOT PRINTED so they won't fade away like printed ones. They also do not have backgrounds so can be placed over any colour background.   Look good on the grid! Self Adhesive.
Pack contains: 6x Numbers to suit rear number plate and front nassau panel. Size approx 70mm wide, 150mm high. 6x Numbers to suit Side Pods. Size approx 45mm wide, 110mm high.
Full set of AKA compliant backgrounds for numbers.
BRAND NEW AKA Legal quality Rear Number Backing Decal 21.5cm x 17.5cm (suits CPR Rear Bumper)
BRAND NEW AKA Legal Vinyl Cut Nassau Decal 21cm x 21cm (suits ARROW and others)
BRAND NEW AKA Legal Vinyl Cut Sidepod Decals (x2) 19.5w x 16.5h (suits Arrow and others)
Select your number combination by typing the two digits you require into the box below.  Select your colour by using the drop down box below.
SKU NPNP3RB
Plate Pack Colour
First Digit
Second Digit
Third Digit
Colour of Numbers
