Home :: Chassis Parts :: Crash bars and linkages :: Nassau Panel Retainer bracket Kit suits Retro bodywork
BRAND NEW set of Nassau Panel Supports
Pair of brackets to suit from top of steering uprights (where the steering shaft is held with a bush) to the top section of the nassau panel (220mm Hole to Hole)
One bracket to suit chasis to bottom of nassau panel (where panel sits above front nosecone - newer style).  (130mm Hole to Hole)
Designed to upgrade older nassau panels to new 'above the nosecone' style or replace a broken/damaged set.
SKU NPBC01
