The new DIY Modular Kart Kits are designed for maximum fun at minimum budget impact. You can spread the cost of the entire build across our 6 affordable modules. Buy just the module you want today, assemble it and get it ready to add the next module later. Each kit comes complete with all the little nuts and bolts, fittings, connectors that all add up. Get the kit and remove the need to spend loads more on all the little things you were unaware that were needed to complete your build. Configure your module with colours of your choice using the easy-to-use configuration wizard. Click "CONFIGURE" at the bottom of the descriptoin to begin building your very own custom kart module. The REAR END MODULE contains: Complete Rear Axle Assembly (available in Silver, Black, Gold, Blue or Red) Brake Cover Guard Hyrdaulic Race Brake System Brake Linkage Rod All required fitting kits, nuts and bolts to complete the fitment of the module to the CPR CHBC01 Chassis. Suitable for larger adults.
Designed for all brands of racing go karts.
NOT SURE HOW TO BUY THIS ITEM? Click here to read our simple walk-through guide.
Brand New |
SKU | BTDIY_M2C | |
Base product price: |
$749.00
including GST 10% |
