Home :: Complete DIY Go Karts :: Modular Kart Kits :: Modular BTDIY Kart Kit - OFF ROAD Wheel Set Module (MODULE 4 OPTION B)
The new DIY Modular Kart Kits are designed for maximum fun at minimum budget impact.  You can spread the cost of the entire build across our 6 affordable modules.  Buy just the module you want today, assemble it and get it ready to add the next module later.
Each kit comes complete with all the little nuts and bolts, fittings, connectors that all add up.  Get the kit and remove the need to spend loads more on all the little things you were unaware that were needed to complete your build.
Configure your module with colours of your choice using the easy-to-use configuration wizard.  Click "CONFIGURE" at the bottom of the descriptoin to begin building your very own custom kart module.
*WE RECOMMEND NOT USING THE BODYWORK MODULE IF RUNNING THE OFF ROAD WHEEL MODULE
The OFF ROAD WHEEL SET MODULE contains:
Front 13" Rim and Tyre Pair (DESIGNED TO SUIT BTCDIY)
Rear 13" Rim and Tyre Pair (DESIGNED TO SUIT BTCDIY)
Fitted and Ready to bolt onto the Previous 3 BTCDIY Modules.
Plus additional spacers required to suit the additonal room on the stub axle compared to the stock slick style rims.
Designed for all brands of racing go karts.
SKU BTDIY_M4BC
Base product price: $229.00
