Home :: Complete DIY Go Karts :: Modular Kart Kits :: Modular BTDIY Kart Kit - Front End Steering Pedals & Seat Module (MODULE 3)
The new DIY Modular Kart Kits are designed for maximum fun at minimum budget impact.  You can spread the cost of the entire build across our 6 affordable modules.  Buy just the module you want today, assemble it and get it ready to add the next module later.
Each kit comes complete with all the little nuts and bolts, fittings, connectors that all add up.  Get the kit and remove the need to spend loads more on all the little things you were unaware that were needed to complete your build.
Configure your module with colours of your choice using the easy-to-use configuration wizard.  Click "CONFIGURE" at the bottom of the descriptoin to begin building your very own custom kart module.
The FRONT END & SEAT MODULE contains:
Steering Wheel (Choose from Blue or Red highlighted flat-top stitched wheels)
Complete Steering Assembly & Fitting Kit (available with Silver, Black, Gold, Blue or Red anodised parts - typically countersunk washers)
Stub Axle Pair, Fittng Kit, all required spacers and stoppers required to complete the steering assembly build on the CPR CHBC01 Chassis.
Pedal Set and Fitting Kit
Seat and Fitting KIt (Choose from a range of colours for your fitting kit)
Brake Linkage Rod
All required fitting kits, nuts and bolts to complete the fitment of the module to the CPR CHBC01 Chassis.
Suitable for larger adults.
Designed for all brands of racing go karts.
SKU BTDIY_M3C
Base product price: $459.00
