The new DIY Modular Kart Kits are designed for maximum fun at minimum budget impact. You can spread the cost of the entire build across our 6 affordable modules. Buy just the module you want today, assemble it and get it ready to add the next module later. Each kit comes complete with all the little nuts and bolts, fittings, connectors that all add up. Get the kit and remove the need to spend loads more on all the little things you were unaware that were needed to complete your build. Configure your module with colours of your choice using the easy-to-use configuration wizard. Click "CONFIGURE" at the bottom of the descriptoin to begin building your very own custom kart module. The 10HP ENGINE MODULE contains: Our renown reliable, powerful and easy to start powerful10hp engine (DESIGNED TO SUIT BTCDIY) (includes fuel line & fuel filter) Complete engine fitting kit (includes all nuts and bolts to SUIT BTCDIY) Clutch (12T GT CLUTCH with Light Shoes & Red Springs fitted) & Throttle Cable BOTH FITTED (DESIGNED TO SUIT BTCDIY) Chain to suit. Rear Axle Sprocket (Your choice of teeth number) Integrated Billet chain guard (DESIGNED TO SUIT BTCDIY) Fuel Tank, Retainer Thumbscrew Spigot for easy fitment of fuel line to tank Designed for all brands of racing go karts.
NOT SURE HOW TO BUY THIS ITEM? Click here to read our simple walk-through guide.
Brand New |
| SKU | BTDIY_M6BCUSTOM | |
| Base product price: |
$9999.00
including GST 10% |
