Home :: Axles & Parts :: Key for Axle 8mm twin Peg style - easy inboard sprocket key (6mm pegs) 30mm hole to hole centre
Single 2-peg key.
8mm x 60mm x 3mm thick (+3.5mm peg thickness) - hole centre to hole centre = 30mm
Peg diameter is 6mm
These are perfect for upgrading your existing axle to an inboard sprocket drive without the expense of milling a new keyway.
Key for Axle 8mm
SKU AKP2S2
