Home :: Axles & Parts :: Key for Axle 8mm Keyway triple (3x 6mm Peg 15mm hole to hole) style - easy inboard sprocket key
Single 3-peg key.
8mm x 60mm x 4mm thick (+4mm peg thickness - pegs are 6mm dia) - hole centre to hole centre = 15mm
These are perfect for upgrading your existing axle to an inboard sprocket drive without the expense of milling a new keyway.
Key for Axle 8mm
18%
SKU AKP3D1
