Home :: Brakes & Parts :: Accessories & Parts :: Hydraulic Brake Line Complete suits BKHC03/4 (Long - 1300mm)
BRAND NEW Hydraulic Brake Line complete unit (twin line 105cm long) suits BKHC03/BKHC04
The listing is for one set, which is actually two 1300mm lines with the two fittings for the calliper and two fittings for the master.  The two fittings can be joined with the twin inlet plug in our BKHC04M master cylinder (also supplied in the BKHC04 brake system).
This can be interchanged with the original BKHC04 700mm lines without any additional items.  You may like to use new o-ring washers which can be found by clicking the link below in the "Related" section.
Suitable for most brands of recreational go karts.
SKU BKHLNL1
