Home :: Brakes & Parts :: Hydraulic :: Hydraulic Brake Kit including Master & Calliper
WHY SHOULD YOU BUY OUR CPR BRAKE SYSTEMS?
PADS AVAILABLE IN STOCK - We've kept the same pad design for over 15 years, ensuring you can buy pads for your CPR system for many more years or decades to come!
SPARE PARST IN STOCK - We always carry parts to service our CPR brand items, in fact you can still buy parts to suit our oldest models over 15 years old!
PERFORMANCE - We source reliable and high performance parts in order to give you the best experience - so you tell your friends.
BRAND NEW Hydraulic Brake Calliper and Master
Approx 70cm long line.
Suit up to 6mm disc.
Replacement pads available from us for $19set.
Line & Fittings are M10 1.25pitch
A= 63mm, B=Up To 6mm, C=37mm (8mm diameter)
Designed for use with DOT3 or DOT4 fluid.
Suitable for most brands of recreational go karts.
Need a brake disc to suit?
30mm Axles:
40mm Axles:
SKU BKHC02
Price with FREE DELIVERY: $119.90
$79.00
$34.95
Brake Pads Linings (suits BKHC02)
Brake Pads Linings (suits BKHC02) Brake Line Hydraulic 6mmOD 4mmID per Metre
$19.95
$7.95
Brake Line adapter adaptor fitting 1/8 BSP (tapered) thread to M10 1.25 Thread (Euro Line to CPR Brake Systems)
Connector Right Angle L for Brake Line (oliveless) Brake Line adapter adaptor fitting 1/8 BSP (tapered) thread to M10 1.25 Thread (Euro Line to CPR Brake Systems)
$9.95
$19.95
$24.90
