Home :: Brakes & Parts :: Hydraulic :: Hydraulic Brake Calliper (Race Type) suits BKHC03/4 (Calliper only, no lines, fittings or master)
BRAND NEW Hydraulic Brake Calliper
This calliper s a 'race-type' assembly which has considerably more stopping power and much larger pads compared to our recreational set (BKHC01).  This kit will work on larger discs (like 12 or 18mm width discs) effectively.
No connections or lines are included.
Suits up to 6mm disc in standard form using the supplied bracket and bolts.
*Suit up to 12mm disc if fitted with optional spacers/washers (not supplied)
*Suit up to 18mm disc if refitted with longer bolts (not supplied).
^Mounting bracket supplied to suit 63mm brackets, or remove bracket and mount each calliper either side of the chassis bracket.  (When used in this configuration minimum disc size is 6mm+Bracket width)
A= 57 or 63mm^, B=Up To 18mm*, C=33mm
- 1x Dual line calliper with 67mm wide pads
Fits our BKHC03 and BKHC04 race brake kits
SKU BKHC04C
$79.00
$34.95
$9.95
$7.95
