Home :: Axles & Parts :: 30mm :: Sprocket Carrier Hub suit 30mm Axle 6mm & 8mm Keyway Silver
Brand new Rear Sprocket Hub / Carrier.
Suits axle diameter: 30mm
Keyway size: 6mm & 8mm (dual option built in)
SKU SHE368
Price with FREE DELIVERY: $49.95
