Home :: Axles & Parts :: 30mm :: Hub for Brake Disc Suit 30mm Axle 6mm or 8mm Key
Brand new Brake Disc Hub / Carrier.
Suits axle diameter: 30mm
PCD 113.5x6 - bolt-to-bolt distance = 56mm
Standard Brake Disc PCD - 113.5mm
Standard Brake Disc inner flange 100mm OD.
Keyway size: 6mm & 8mm (both keyways are milled in the hub)
SKU BHK368
