Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Honda Clone Carburettor CPR Performance Bored 0.685" METHANOL Suit GX200 & Honda Clone
Honda Clone worked and blueprinted Carburettor
PROFESSIONALLY MODIFIED
Our Honda-Style 0.685 Methanol carbs have been professionally re-worked by reputable technicians to ensure the highest quality of workmanship and accuracy.
IMPROVE PERFORMANCE
Not only will a new 0.685 Methanol high-flow carb increase performance from your Honda GX200/Predator engine, but a new carb will add additional reliability to ensure you finish every race so you can concentrate on driving faster.
READY TO FIT
Set up out of the box ready to bolt on and go - our re-worked carbs will only need a main-jet tweak depending on the amount of modifications you have on your engine. Ffit it and experience a new level of performance from your engine!  Easy!
Carburetor, GX200 MAX Bored Out and circuitry reworked ~17.4 mm (.685). 100% Bolt on.
Designed for use with Methanol fuel, this carb will produce the maximum power possible from a stock appearing carb and is tuned for WOT performance.  Due to the nature of the modifications there will be some loss of low end and throttle reesponse.  Depending on weather and engine modifications, richer or leaner jetting may be reuqired.  Adjust idle mixture screw to improve idle.
WARNING The walls of these carbs are very thin, use extreme caution when changing jets and/or adjusting the carb.
Includes 150 Jet (fitted)
Pilot Jet .028 (fitted)
Emulsion Tube:  Methanol
SKU CHGB685M
