Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Honda Clone Carburettor CPR Performance Bored 0.670" Suit GX200 & Honda Clone
Honda Clone worked and blueprinted Carburettor
PROFESSIONALLY MODIFIED
Our Honda-Style 0.670 carbs have been professionally re-worked by reputable technicians to ensure the highest quality of workmanship and accuracy.
IMPROVE PERFORMANCE
Not only will a new 0.670 high-flow carb increase performance from your Honda GX200/Predator engine, but a new carb will add additional reliability to ensure you finish every race so you can concentrate on driving faster.
READY TO FIT
Set up out of the box ready to bolt on and go - our re-worked carbs will only need a main-jet tweak depending on the amount of modifications you have on your engine. Ffit it and experience a new level of performance from your engine!  Easy!
Carburetor, GX200 MAX Bored Out and circuitry reworked ~17.0 mm (.670). 100% Bolt on. Approx 0.7 hp more than stock carb depending on application. recommended for modified motors using CPR Performance Chrome Moly rod and 272 or bigger cam as well as head work.
Includes 98 Jet (fitted)
SKU CHGB670M
