Home :: Engines, Carbs & Parts :: Engines :: Heavy Duty Roller Tip Valve Rocker Arms Pair CPR Performance 1:1.2 Ratio Suit GX200
Complete kit of 2pcs.
These are heavy duty re-enforced Steel Billet 1:1.2 Ratio rockers with Roller Tips for continual high rpm use with heavy duty valve springs 24lb+ and dual valve springs.  Race Proven.
Machined from chrome moly steel billet
  • Hardened roller tips and shafts
  • Dyno tested to 10,000 rpm and proven to make more horsepower
  • Uses stock shaft & Pivot Nut
Fits under stock valve cover.
These Rocker Arms require shorter Pushrods, typically 5.160 or 5.110 depending on cam and head milling.
CPR Performance Rocker Arms, 1:1.2 Ratio. SET OF TWO PIECES
HeadTearDownGuide
SKU EVRTN12
