Home :: Engines, Carbs & Parts :: Engines :: Head Gasket CPR Performance Fibre with Fire Ring Suit Honda Clone GX270 (Ideal for high compression engines)
Fibre CPR Performance Honda & Clone GX270 Head Gasket.
BSP/Clone High Performance Head Gasket
This is a fibre with fire ring gasket - seals better than the steel ones - ideal for high compression engines.  Approximately 1.3mm thick.
Viton is an extremely durable, heat resistant coating that is used to insure better sealing than a untreated, stock gasket.
HeadTearDownGuide
SKU GHLC27
