Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Aftermarket Tillotson HL-334W Carb Overhaul Rebuild Gasket Kit suit CTHL344
Aftermarket Tillotson HL-334W HL-334WX Carburettor overhaul kit (seal kit) as pictured.
Suit CPR CTHL344 Tillotson Carbies.
Does your carbie seal properly? Do you hold pressure on pop-off? If you don't, or you're not sure, you need to replace your needle. Cheap and effective way to maximise horsepower and correct starting problems.
7%
SKU RK334
