Home :: Tachos, Laptimers & Gauges :: Tachos & Speedometers :: Go Kart Speedometer + Tacho + CHT Temp + Hour meter Gauge (IP65 Weatherproof) with mounting bracket
Our latest combo Speedometer also includes hour meter with service intervals, Tacho, Temp guage (CHT) and clock!
This is the latest model.  NOW WITH LARGE 42.6 x 56.6mm DISPLAY!
THIS SPEEDOMETER CONTAINS A NON-REMOVABLE RE-CHARGABLE BATTERY - it WILL operate correctly without connecting the 12V leads included with the kit.  However, an external battery or power supply from 10V-24V (ideal to use with battery for electric start motors) will be required from time to time to recharge in-bulit rechargable battery.  If being used on a vehicle with a 10-24V battery then there is no need to re-charge the inbuilt battery as it will be kept topped up at all times.
INCLUDES MOUTNING BRACKET!
See attached pictures.
Size - 68mm High, 118mm Wide, 26mm Thick.
Designed for go karts.
DOWNLOAD THE MANUAL
SKU TSRTC1
