Home :: Washers, Spacers, Springs, Nuts & Bolts :: Bolts & Nuts :: 8mm :: Go Kart Countersunk Bolt M8 70mm long High Tensile NEW with Nyloc & Washer
BRAND NEW Countersunk black high tensile bolt.  These fit our 8mm ID Countersunk Washers.
M8.  70mm Long.
Complete set includes washer & nyloc nut.
M8 suits Steering Bush, Inside Tie rod ends, Seats, Brake mounts, Axles and carriers....
We supply these 70mm bolts with steering uprights and steering bush packs.  They are perfect to hold your steering column to your uprights through the black or red plastic bush.
Go Kart Countersunk Bolt M8 70mm long High Tensile NEW with Nyloc & Washer Set
SKU BCM870S2
