Home :: Sprockets & Chains :: 35 Pitch Chains :: Go Kart Chain High Performance RLV GOLD 35 Pitch 106L (~1m) BRAND NEW
This is the GOLD on GOLD premium verson.  Highest grade available.
35 Pitch Chain 97cm (106L) with master link / joiner (part of chain).
Designed for 4 stroke go karts.
Extreme GOLD Premium RLV quality for racers wanting the absolute best quality chain for their high performance machine.
Our RLV Chains use a patented angular seam bushing formed from strip steel.  These are die-sized around a precison mandrel to create exceptional roundness leading to superior strength and incredible wall thickness consistency.  This produces a chain with lower fatigue rates and extremely low failure rates.
Our RLV chains provide:
- Reduced Joint Wear (stretching/elongation)
- Improved busing endurances (bushing cracking)
- Reduced sprocket wear
- Smoother chain engagement
- Reduced drive system vibration
- Improved chain fatigue resistance
- Improved busines retention (inside chain bar)
- Reduced drive system noise
THE BEST #35 CHAIN AVAILABLE
RLV Chains are manufactured to stringent controls offering reduced joint wear (stretching/elongation) Improved bushing endurances (bushing cracking) reduced sprocket wear, smoother chain engagement reduced drive system vibration and noise and improved chain fatigue resistance.
MASTER LINK INCLUDED
RLV #35 chains include a master link/joiner so that you can easily adjust the length as well as remove and install quickly and easily on inboard drive vehicles.
RACE RELIABLY
Ask our toughest critics - the local guys at your track. If they’ve been using RLV chains we guarantee you they are experiencing the absolute lowest amount of failures compared to other chains.
Suitable for #35 pitch drive systems.
SKU CHNRLVG
Clutch Dry SR Series 35 Pitch 18 Tooth 19mm (3/4inch) bore
Clutch Dry SR Series 35 Pitch 18 Tooth 19mm (3/4inch) bore Sprocket Split Aluminium 35 Pitch 64 Teeth
$49.95
Sprocket Split Aluminium 35 Pitch 69 Teeth Go Kart Chain Master Link Joiner 35 Pitch BRAND NEW
