Home :: Washers, Spacers, Springs, Nuts & Bolts :: Bolts & Nuts :: 10mm :: Go Kart Brake Banjo Bolt Dual Outlet with seals (suits BKHC03 BKHC04 & BKHC05 models)
BRAND NEW
Banjo bolt to suit our BKHC03, BKHC04 and BKHC05 hydraulic brake systems.
Allows tow banjo fittings to be connected - run dual lines on master or use to couple from one side of the calliper to the other.
Includes two o-ring washer seals.
SKU BBBDC1
