Home :: Clutches :: Go Kart 10T Clutch 219 Pitch Suit KT100S Short Shaft Base Product (PRE-ORDER)
THIS ITEM IS NOT IN STOCK - THIS IS A PRE-ORDER SALE - ITEM WILL SHIP ONCE ARRIVED IN THE CPR WAREHOUSE
BRAND NEW quality ITALSPORT RED Dry centrifugal clutch with 10T 219 Pitch drive sprocket.
Clutch suits KT100S (Clubman) Engines with Short Shafts.   (Click here to learn how to identify KT100 shaft sizes)
Complete with all components
- Starter Bolt
- Retention Nut
- Bronze Bush
- Clutch Drum & Sprocket
- Bearing Sleeve
- Bearing Clutch Centre
- Clutch Centre/locking collar/torque screws
- Clutch Cover
- Cap Screws for clutch cover
- Complete fitting instructions
KT100ShaftGuide
SKU CLRKTSS_PREORDER
Sprocket Front (KT100 Long Shaft Red Clutch) 219 Pitch 12 Teeth
Sprocket Front (KT100 Long Shaft Red Clutch) 219 Pitch 10T 10 Teeth
Sprocket Front (KT100 Long Shaft Red Clutch) 219 Pitch 12 Teeth Sprocket Front (KT100 Long Shaft Red Clutch) 219 Pitch 10T 10 Teeth
$59.90
$59.90
Sprocket Front (KT100 Long Shaft Red Clutch) 219 Pitch 11 Teeth
Sprocket Front (KT100 Long Shaft Red Clutch) 219 Pitch 13 Teeth
Sprocket Front (KT100 Long Shaft Red Clutch) 219 Pitch 11 Teeth Sprocket Front (KT100 Long Shaft Red Clutch) 219 Pitch 13 Teeth
$59.90
$59.90
