Home :: Engines, Carbs & Parts :: Gasket Set Rebuild Kit Genuine CPR suits Vacuum Fuel Pump (FPEC01)
Full 8pcs Gasket and Rebuild Set Kit.
Genuine CPR
Suits FPEC01 CPR Vacuum operated Fuel Pump.
Is your pump leaking air, or failing to draw fuel properly?  Over time the rubberised gaskets are degraded by the additives in high octane fuel and need to be serviced or replaced.
SKU GFPEC1
Vacuum Manifold Sandwich Insulator for External Fuel Pump GX160/200 and Clone
Air Filter suits Upgrade Kit for 4-Stroke Engine Vacuum Manifold Sandwich Insulator for External Fuel Pump GX160/200 and Clone
$26.95
$34.95
Air Filter Upgrade PACK suits GX200 Style 6.5hp Honda & Clone 4-Stroke Engine
$79.95
