Home :: Engines, Carbs & Parts :: Head & Valve Train, Cams :: GX160 GX200 Predator Torini Heads Valvetrain Cams :: GX200 Valve Rocker Tappet Cover Spacer Aluminium with Vacuum Port
These are required when using roller rocker style rocker arms which sit higher than the available space under the stock rocker cover.  Provides 16mm additonal room between inside of rocker cover / valve cover and top of rocker arms/studs.
Includes new gasket, all fittings.
Also includes barb for tapping vacuum for vacuum operated pumps (instead of using vacuum sandwich in inlet manifold)
SKU EVCSN1
