There are two ways you can go about #2. The easiest is to buy our kit with the sidepod bars included, then modify our sidepod bar to fit your kart. This usually involved bending one or both of the front/rear bars to suit, or in some cases it may require an extension of the front bar (usually when the bar plugs into the front of the chassis on an angle, rather than perpendicular). The second solution is to modify your existing bars although this is tricker because you’ll need to align the re-inforcement rail, as well as align the tabs with the nutserts inside the sidepod.
