GUIDE
Servicing Bully Clutches - Disassembly and Assembly Tutorial
This month we're showing you how to break down and re-assemble your Bully twin disc clutch, and we'll also give you the tips and tricks to service it and keep it in the best operating order.
*NOTE: This assembly guide shows the 3-disc 3/4" model, but the process is identical for the 1" 4-disc model, except there is an extra friction disc and floater disc. Also, the screws holding the lever plate to the transmission gear are torx screws on the 1" model.
CONTENTS
1. Remove the Engagement Adjustment Screws
2. Remove the Lever Support Plate
3. Dis-assemble the Lever Support Plate
4. Remove the Pressure Plate assembly
5. Remove the first Friction Disc
6. Remove the first Floater Disc
7. Remove the second Friction Disc
8. Remove the second Floater Disc
9. Remove the third Friction Disc
We have been advised officially by that standard BRAKE CLEANER CAN BE USED TO CLEAN ALL SURFACES (ON OUR Bully CLUTCH - THIS IS ALSO CORRECT FOR THE BULLY CLUTCHES) - specifically friction disc, housing, transmission plates etc. Remember to grease any surfaces which require lubrication prior to assembly.
Remove the clutch from your kart and clean off any debris and excess chain lube, inspect keyway for wear or deformaties
In our example below, the sprocket has already been removed - if yours is still attached, remove the circlip at the top of the clutch, then the thrust washer, then remove the drum/basket. On the underside of the basket, remove the circlip then push out the sprocket - if it's stuck, use a nylon hammer or similar to gently knock the sprocket out from the rear of the drum.
Measure the spring height on each spring and record your height, then remove bolts washers and springs. Stock setting is approximately 7mm out.
Remove the drum/basket then carefully remove the thrust washer and bearing set - do not lose the pieces - there are 2 thrust washers and one bearing. If you require a new bearing and thrust washers they can be found here:
.jpg)
.jpg)
.jpg)
.jpg)
Turn the unit over.
Using a socket and ratchet, remove the 6 spring loaded adjustment screws.
.jpg)
.jpg)
Carefully lift the Lever Support Plate up and away from the Bully body. Flip the plate as soon as it is clear of the body - do not use jerky movements so as to avoid the levers from falling out. Place carefully on a surface, preferably in a container like an empty plastic ice cream container, or a bucket, or similar vessel.
Check the plate for any wear.
Slide the pressure plate assembly carefully upwards and off the body of the Bully. Inspect for any wear where the engagement levers rub.
Slide the Floater Disc carefully upwards and off the body of the Bully. Check for wear and abnormailties. Replace if necessary.
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
