Home :: Tachos, Laptimers & Gauges :: Temperature Gauges :: GT Cylinder Head Temperature Replacement Sensor suit TTEMPGT CPR Temp Gauge (Long) (CLONE)
*NOTE: THIS ITEM FITS THE NEWER GT GAUGE, NOT THE OLD TTEMP1 GAUGE SOLD UP UNTIL AUGUST 2020. If you bought a gauge after August 2020, then this item will fit your gauge*
Replacement lead to suit CPR TTEMPGT Temp Gauge.
Lead length (160cm total when fitted to Gauge)
Sensor Inner Diameter = 14mm
Designed for go karts.
CHTGuide
SKU TTESCHLGT_HP
