Home :: Tachos, Laptimers & Gauges :: Tachos & Speedometers :: GT Cylinder Head Temperature Replacement Sensor suit TSRTC1 CPR Speedometer (VERSION 2)
Replacement lead to suit CPR TSRTC1 Speedometer
THIS MODEL HAS TWO REPLACABLE/INTERCHANGABLE PLUG TIPS.  ONE IS A 90 DEGREE ELBOW VERSION, THE OTHER IS A FLAT VERSION.  SENSOR IS FITTED WITH A NUT AND CAN BE REMOVED/REPLACED.  SUITS CHALLENGING INSTALLATION SPACES.
Lead length (118cm total when fitted to Gauge)
Sensor Inner Diameter = 14mm
Designed for go karts.
CHTGuide
SKU TTSLTV2
