Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Fuel Jet Fully Adjustable suit GX390 Honda Clone Engines (can work with GX270)
Don't risk dangerous lean condition of your engine when increasing breathing power by additon of aftermarket exhausts/mufflers and Air Filters or other intake upgrades on your Honda clone engine.  Get one of our adjustable fuel jets and always have the right jet handy.
Simply replace your exisiting jet and adjust the screw to desired mixture.  Experiement and add any upgrades you like and always know you have the right mixture available.
Includes adjuster, fuel jet (EFJBM170) and pilot jet.
Adjust easily to suit daily humidity and temperature changes.
FITS:  GX270 & GX390 engines. *NOTE: WIth GX270 engines you will need a smaller jet than the one supplied in the kit - the kit is designed for GX390.  About a 120 jet is ideal for GX270 and the adjjustable jet.  It is not recommended to use the pilot jet supplied in GX270 engines.
SKU EFJAN3
