Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Fuel Jet Fully Adjustable suit ENCL65 and all GX160/200 Honda Clone Engines
Don't risk dangerous lean condition of your engine when increasing breathing power by additon of aftermarket exhausts/mufflers and Air Filters or other intake upgrades on your Honda clone engine.  Get one of our adjustable fuel jets and always have the right jet handy.
Simply replace your exisiting jet and adjust the screw to desired mixture.  Experiement and add any upgrades you like and always know you have the right mixture available.
Includes adjuster, fuel jet and pilot jet.
Adjust easily to suit daily humidity and temperature changes.
INSTALLATION UPDATE:
1. Remove the adjuster from the bolt
2. Install the bolt into the carburettor
3. Screw the adjuster into the bolt
4. Adjust the carburettor to where you want it to be
5. Run the two nuts up tight against the spring (so that it will stay adjusted and will not leak)
SKU EFJAN2
