Home :: Wheel, Tyres & Front Hubs :: Rims :: Front Wheel Hub Hubs PAIR suit 17mm Stub Axle TOUGH STEEL OFF-ROAD Model
TOUGH STEEL for OFF-ROAD purposes
FITS 17mm Stub Shafts
With standard 50mm x3 PCD our hubs will fit standard race kart wheels and our 13" off-road wheels.  Fitted with 17mm ID sealed bearings, they will suit 17mm stub shafts common to all of our CPR stub axle kits.
Front Wheel Hub/Carrier PAIR.
Two pieces in this set.
Plated Steel.
40mm Length (Short) from wheel mount face to ouoter rear bearing face
Outer Bearing Face to Outer Bearing Face = 40mm (this is the amount of the stub shaft this wheel will utilise - spacers will be required to pad out the additional length of your stub shaft)
Suit 17mm Stub Axle.
Designed for converting most brands of go karts to off-road systems, or projects for off-road including racing mowers.
SKU WHFCS
Wheel Spacer Washer 5mm Anodised Silver
$2.99
