Home :: Wheel, Tyres & Front Hubs :: Rims :: Front Wheel Hub Hubs PAIR suit 17mm Stub Axle Gold (WITH BEARINGS AND STUDS)
Front Wheel Hub/Carrier PAIR.
Two pieces in this set.
70mm Length (Medium).
Suit 17mm Stub Axle.
*NOTE: When used with STAC1 stub axle/spindles the bearing spacing requires one additional 5mm wheel spacer washer per side.  These can be found by CLICKING HERE
SKU WHFC1G_KNK_WITHBEARINGS
