Home :: Wheel, Tyres & Front Hubs :: Rims :: Front Wheel Hub Hubs PAIR suit 17mm Stub Axle Blue
BILLET ALLOY PERFORMANCE
FITS COMMON RACE KARTS
COLOUR CHOICES
Front Wheel Hub/Carrier PAIR.
Two pieces in this set.
Colour as pictured.
70mm Length (Medium).
Suit 17mm Stub Axle.
Outer Bearing Face to Outer Bearing Face = 65mm (this is the amount of the stub shaft this wheel hub will utilise - spacers will be required to pad out the additional length of your stub shaft)
*NOTE: When used with STAC1 stub axle/spindles the bearing spacing requires additional wheel spacer washer(s) per side.  These can be found by clicking the 'related items' tab below.
SKU WHFC1B
Wheel Spacer Washer 5mm Anodised Blue
$2.99
