Home :: Tools, Starters & Chargers :: Tools :: Front Wheel Aligner - Laser SNIPER System
SNIPER Laser Front Wheel Aligner complete.
Are you struggling to win races?
Got a spongy, understeering or oversteering kart you just can't seem to fix no-matter what you throw at it?
Your front end probably isn't set correctly You might have used manual tools to try to get it right, but it's hard particularly if your chassis isn't 100% true. This method uses lasers and is 100% accurate.
You'll be amazed at the incredible results you'll get from using this tool - customers have literally transformed rear of field karts to competitive front running machines!
The most accurate way to ensure the absolute best performance from your chassis.  This tool has proven to improve chassis handling time and time again - ask someone at your track if you're not convinced - these are being used by everyone who is winning.
Incorrectly aligned wheels will cause premature tyre wear, will cause under and oversteer, vague handling, loose rear ends, pushing front ends, karts that turn one way better than the other, lack of grip, and loads of other race-losing issues.  Use one of these tools to ensure you are providing the absolute best possible performance from your chassis when delivering the maximum engine power through to your rear wheels.
Get the SNIPER STEERING ALIGNMENT TOOL and DRIVE FASTER!
ALIGN STEERING PROFESSIONALLY
Do it the way the pro’s do it in their kart shops.
Just attach the sniper aligner tools to your stub axles by using the sniper magentic base and adjust quickly and precisely with the in-built laser.
Camber, Castor and Toe can be easily and quickly set.
WORKS WITH ALL KART SPINDLES!
Designed to suit all standard go kart spindles/stubs your kit can connect easily to any steel composite spindles magnetically, or for non-magnetic stubs simply use cable ties or a similar tie to fix them to your stub axle.
DROP LAPTIMES FAST
Drive faster by correctly aligning your front end (wheels) to dramatically improve all handling characteristics including grip, turn-in, understeer and oversteer.  Clientss have reported huge differences in chassis control and laptimes when using the sniper aligner.
Learn how to use the sniper system by clicking this link
The V2 Inox Contains:
1 Set of Sintered 316 Stainless Steel V2 Inox bodies
1 Set of spare batteries
1 Stainless Steel Rule
1 Rare Earth Magnet
1 Instruction
1 Packaging
With this tool you are able to easily measure-
Toe Camber
Compare Castor Wheelbase
Chassis Twist
Check your 'dynamic' reading, letting you know what your kart does on the track It can also diagnose bent King Pins and Spindles.
Fits onto any Spindle upto 63mm (2 1/2 Inch) Diametre.The V2 Inox is a 2 laser system which lets you quickly and easily set camber and toe on you kart.
It gives the ability to measure static (kart on the trolley) and dynamic (kart on the ground with driver in place) so you know exactly how the kart responds.
This system is suited for everyone racing karts, ideal to be used at the track between races to alter setup or to check alignment.
SniperAlignementGuide
NEW
SKU TFWAS1
$279.00
