Home :: Airboxes, Filters & Parts :: Front End Complete (clamp type) Brand New With Red Countersunk Washers
YOU GET ALL THIS!  Valued at over $820!
Complete Front End setup from Rims to Steering Wheel.  Consists of the following items:
1. Set of Stub Axles
2. Complete Steering assembly Kit
3. Steering Wheel
4. Front Racing-type Rims
Includes everything to bolt it all together, plus free anodised washers.  (SELECT COLOUR OF WASHERS AT BOTTOM OF DESCRIPTION - Red, Blue, & Gold available)
------  1. CLAMP-TYPE STUB AXLE KIT COMPLETE  ------
Designed as a direct replacement to fit PCR AND MANY OTHER KART DESIGNS where bearings are fitted to frame rather than the stub axles themselves.
Colour: Black
TYPE: Clamp - Bearings contained in kart frame
INCLUDES SPACER WASHERS (One set of 8 - 4x10mm & 4x5mm spacer washers - Colour as per title & title picture)
INCLUDES WHEEL NUTS
KING PIN Diameter: 8mm, 10mm or 16mm.  (SELECT either 8mm or 10mm with the box at the bottom of this description)
Dimension A: 70mm (outer to outer - ie: full width/height)
Dimension B: 60mm
Dimension C: 90mm
Dimension D: 100mm
Dimension E: 113.5mm
Dimension F: 22.5 degrees of camber adjustment
Click the pictures above to enlarge to see the dimensions.
Here's what you'd expect to pay for all the items separately on eBay:
Stub Axle Pair - $199
2x Nyloc Wheel Nuts = $8.00
2x Hi-Tensile King Pin bolts,washers, nuts = $20.00
8x Wheel Spacer Washers Anodised Purple = $20.00
Postage - Add Approx. minimum $25 individually from different sellers.
Total Value $272.00
------  2. STEERING ASSEMBLY KIT COMPLETE  ------
ABSOLUTELY BRAND NEW complete steering assembly! Bolt-on and GO!
Comes with everything you need to connect it up and use. PLUS FREE countersunk washers, bolts and nuts.
BOSS - $34.99
3x Boss Countersunk Washers Anodised = $8.00
3x Boss Countersunk High Tensile Bolts & Nyloc Nuts = $6.00
SHAFT - $35.00
4x TIE ROD ENDS - $40.00
2x TIE RODS - $35.00
4x Tie Rod Countersunk Washers Anodised = $12.00
4x Tie Rod Countersunk High Tensile Bolts & Nyloc Nuts = $12.00
1x Nylon Steering Bush (NOT PICTURED, BUT SUPPLIED) = $9.90
Postage - Add Approx. minimum $75 individually from different sellers.
TOTAL VALUE =  $267.90
Dimensions:
Dimension A: 480mm
(Depending on tie rod length chosen - select from the drop-down box below):
Bottom of shaft (Bottom of A) to Tie Rod Holder (where B&C Meet) = 60mm
------  3. STEERING WHEEL COMPLETE  ------
BRAND NEW leather-look steering wheel. Stitched.
Alloy Centre 320mm Diameter (COLOUR - SELECT FROM DROP DOWN LIST AT BOTTOM OF DESCRIPTION - AVAILABLE IN BLUE AND RED)
These sell for approx $100-$130 in stores plus $15 shipping.
Really nice looking and feeling Go Kart Steering Wheel.
Total Value = $145.00
------ 4. FRONT RIM SET ------
BRAND NEW PAIR of Front Rims
High Speed Low Friction Bearings Installed 17mm ID - Suit 17mm Stub Axle
Offset (inner bearing flange in line with inner rim flange)
130mm Wide
5" Diameter
High Quality turned aluminium alloy.
These sell for around $80 per rim ($160 pair) in stores.
Total Value = $160.00
SKU XFRCC2R
Base product price: $999.00
